Quick question
If the current requirement of your video receiver is less than 500mA then yes
Since you told it runs on battery i guess the current required by your receiver is very less so there will not be any problem using the wall plug
Reading between the lines here, were you affraid that a 500mA output could fry something?
See, the wall adapter doesn't output 500mA, but it *can* output up to 500 mA. The actual output depends on the target circuitry which will draw what it needs. Up to 500mA.
Plug a device rated 9V 750mA and see what happens. Just kidding ;)
moody07747 said:
"I reject your reality and substitute my own" -Adam Savage (Myth busters)
I love that show :)
There's a bit more to these plug in wall adapter devices. A cheap (tranformer/rectifier) one has a poor voltage regulation, you may get 11 or 12V at low current draw and just under 9V at 500mA.
If you have a switch mode plug pack then the output is much more stable, as you would expect for the extra price :wink:
Klaus
Indeed. But that knowledge probably won't help moody grasp the basic concept I was trying to explain, and chances are it is a lot more confusing than helping here.
But hey, here's your chance to be helpful :
I use a 19V wall plug that came with an old laptop. It's rated at 2.4A. When powering small circuits drawing anywhere between 10 and 200ma, the output is a steady 19.4V. What can I expect when I get near 2.4A? Same voltage? A bit closer to 19.0V? Or lower than 19V (which I doubt)?... Would this qualify as a nicely regulated supply?
i have an old gateway power pack
ill have to try plugging that in
I think what Klaus is trying to say is:
If the TV receiver is built for battery use only (no external power connector). Then it probably won't have much voltage regulation inside ('cause a battery is pretty clean power by itself)...
If you connect an unregulated 9V wall-wart wich, when the load is not high enough, will put out more then 9V (12 or maybe more) it could damage your receiver...
