Hi, I've got a few questions about my design and i am open to improvements. At the moment this is just one channel (mono), i'll duplicate and use dual pots once it's done.
I've assembled it on a breadboard and works well as far as i can tell. The only thing i haven't done yet is run it from a 9v wall wart (get one tomorrow), i use a power supply.
I've used a sine wav generator and my mp3 player connected into my old koss mini-system and an older oscilloscope to check how well it behaves. The filter seems to work well.
The power is from a 9v wall wart, regulated with a LM7809 (IC1).
Inputs go into IC2A, the inverting summing opamp (single supply) with a gain of 14.
Summed signal goes thru the Baxandall filter around IC2B and goes to the line-out buffer (IC2C) and to the half wave peak detector (IC2D) which sends a vcc/2 biased voltage to the LM3915 logarithmic led driver controlling a led bar (3 green 4 yellow 3 red).
EDIT: The LM3915 is in dot mode.
Caps C1 to C7 are film type, resistors in Baxandall filter resistors are 1%.
Questions:
1)Biasing non inverting inputs for single supply opamps: What are the 'rules' for determining the values for the resistors and caps? The 100 nf cap i understand is for transients but how big (or small) must the larger one be? Resistors, why 10K or 100K?
2) Can i use one voltage divider / cap network so supply the vcc/2 bias for TWO opamps (on the same side of chip and the transient cap between pins) or should they really have each their own dividers and caps.
3) Output cap size: Is the frequency formula here the good old 1/(2*pi*R*C) where R would be the expected input impedance of the equipment we are plugging the mixer into? I believe that is normally 10k?
4) I've often read that 9v wall warts give 12v unregulated. With diode D1 (1n914) in the path, is this reliable enough for the LM7809? I guess i'll see tomorrow...
EDIT 5) I've sometimes seen a small cap (27pf - 47pf) in parallel with the feedback resistor in inverting opamps (R5 in my schematic). I presume this is to filter out very high freq. Is this desirable and if so what is the formula to determine the cap value?
Any improvements or preventive measures are welcome.
Questions:
