Sceadwian said:Gramo, ceramic resonators are less accurate and stable than crystals, not more. The crystal will work just fine. If you need to fine tune the exact frequency of the crystal you can use trimmer caps, but calibrating the whole setup can be a bit finacky.
The ceramic resonator is often used instead of crystal because of it's lower price. The frequency accuracy is not as good as a crystal but in many application the accuracy is not critical.
Hero999 said:Why do people use ceramic resonators then?
They certainly aren't much cheaper than crystals so why bother?
