Question concerning capacitors
WildStriker
Does anyone know how you can work and calculate the value of a capacitor in an rc circuit if you have a resistor of 1 kilo ohm with a cut off frequency of, for example, 2.5 kHz?
Comments will be appreciated.
Cutoff frequency is subject to how you define it. It tends to be simplified as a two-line graph with zero slope and then a ramped slope. In reality it is on continuous gradual curve. But traditionally, cutoff frequency -3dBi which is half the power (or 70.7% the magnitude). Then that is this formula:
f(Hz) = 1/(2*pi*RC)
radians(Hz) = 1/(RC)
f(Hz) = 1/(2*pi*RC)
I'm quite confused. The question is asking how I could calculate the value of the capacitor (C), required to meet the frequency response (2.5kHz)
Is this it, C=1/2*3.142*fR?
At the cutoff frequency, Xc = R
or 1/(2Π*2500*C) = 1000
I'll let you do the algebra.
I'll try and rephrase the question for clarity,
If you have a low pass filter rc circuit (with a cut off frequency of 2.5kHz) with a 1 kilo ohm resistor, how do you theoretically calculate the value of the capacitor?
If you have a low pass filter circuit diagram (with a cut off frequency of 2.5kHz) with a 1 kilo ohm resistor, how do you calculate the value of the capacitor required to meet the frequency response?
You solve the equation I gave you for C!!!! You can do that, right?
Think your calculator is broken. Just looking at the equation one should be able to assume you're many orders of magnitude off.
funny, I get 63.366 nF
I'm confused now. I did the equation again and it gave me 15700000. Is it okay if you can you walk me through your calculation on how you got 63.3 nF?
I followed the equation as 2*3.14*2500*1000 then divide 1.
there's your problem, it's 1 divided by (2 * 3.14 * 2500 * 1000) and not the other way around
so this works out to 1 divided by 15707963.27
How does 2*3.14*2500*1000 = 15707963.27? I get 15700000. I still don't understand. And yes I took bodmas into account but my answer still differs.
I putted in on my calculator 1/(2X3.14X2500X1000) and gave me 6.3694267519
Sorry if I'm causing any trouble.
2*pi*2500*1000 = 15707963.27
1 / (2*pi*2500*1000) = 63.366 nF
the reason you get 15700000 is because you're rounding pi to 3.14 and I get 15707963.27 because I am not rounding pi
either way makes little difference and you can probably use either number, with your number you get:
63.7 nF
with my number you get:
63.3 nF
your capacitor is going to have a % tolerance where the 0.4nF calculation difference isn't going to make a difference
63.7 nF
63.3 nF
Okay thanks.
One last question, when calculating the microfarad (uF) of the capacitor, do you still follow the samr formula?
umm, micro, nano, pico, milli, etc...these are just standard unit prefixes. I'm sure you're familiar with millimeters, centimeters, meters and kilometers right? Basically that's just 1/1000 of a meter, 1/100 of a meter, 1/1 of a meter and 1000/1 of a meter right? Or in other words 1m * 10^-3 for millimeter (or mm). So a micrometer is 1/1000000 of a meter (10^-6 meter), or a micrometer is 1/1000 of a millimeter. A nanometer is 1/1000 of a micrometer and a picometer would be 1/1000 of a nanometer.
Here's one of hundreds of sites that explain unit prefixes: http://www.telecomabc.com/p/prefix.html
