PointOnePA
I'm reverse engineering an X-Y matrix on a device (a pump) so that it can be controlled by a computer. The devices is old and uses an Motorola MC146805 process. My plan is to insert a PhotoMos relay in place of each key contact so that I can run the thing remotely.
http://www.electro-tech-online.com/custompdfs/2009/07/AQY272.pdf
I've already have the on/off pushbuttons working, but they are not in the x-y matrix but instead go to individual components. The problem that I am having is with the matrix'ed swtiches. I can toggle any one switch with a PhotoMos realy, but when I hook up multiple switches, those that share a driving line don't work.
This x-y matrix is a little different than typically. Instead of having power from the supply, as in this reference note (figure 3),
http://www.electro-tech-online.com/custompdfs/2009/07/AN_660_0.pdf
Instead, power is supplied from the MC146805 pins. Then, there are current limiting resistors (10K) going to ground that are used to generate the voltage for the key detection line. 3 supply pins; 3 detection pins; Also, this is a 6.8 volt device, (I said it was old).
I'm assuming that the keypad is just a bunch of switches and nothing else, (I've not been able to disassemble it, but from my resistance tests that appears to be true). I have no control over the MC146805 timing, but it should just be a matter of contact closure.
So my questions is, could the PhotoMos relay be ringing? The on spec is 1ms with an off time of 0.1ms.
