In many circuits you can see that when a lot of leds are needed in parallel (for example ten leds connected to the outputs of a 4017) a separate resistor is used for every led. I wonder why that is. Isn't it possible to just use a single resistor which is connected from ground to all the 10 leds and then each other end of the led to an output of the 4017?
Greetings,
Greetings,
