Pwm
Angy
Hello all,
I'm looking to vary the duty cycle of a PWM signal with a reference of 0-10V.
Is there any way of doing this using a dspic33?
Thanks for your help. Any ideas will be greatly appreciated.
Do you have any kind of sample code that I could use as a template?.This is for a dspic33f,I'm looking at the PWM sections of the datasheet and I'm completely confused as to set the pwm registers!
Take a look at the Microchip 16 bit **broken link removed** for something to look at. I find the Microchip code is not always readable, but hey, you might get lucky.
Yes, I need to do this using dspic, that is the project definition.Any help will be greatly appreciated.
Try reading the section of the PDF for your chip that describe the PWM hardware.. It's all in there. No one in the forums minds helping, but asking questions that are fully described in datasheets that you have available to you is not something most people like to do =)
General questions
Believe it or not, the best start is always the datasheet.
Questions with such an ample scope should be solved (or tried to) reading the datasheet and then coming here with more specific questions.
You must do the inital effort.
I've already read the data sheet many times and PDCx duty cycle registers sets the dutycycle for the pwm. I got a pwm signal out of the system but My problem is not the duty cycle but the pwm time period or(freq) that I need to tune.I started changing the values on the PTCON or pwm time base register but the output still is not the desired value that I need. I'm not sure if I'm missing anything here, can someone help?
You may not be able to get the 'desired value' you want, the frequencies hardware PWM can put out at a given bit depth for the duty cycle are limited. What exactly are you trying to set the frequency to?
