I built "Kit67" from my local electronics shop and it works great. I would like to change the output mosfet to allow me to run much higher current. The kit comes with one IRF530 N-Channel Mosfet which is only good for around 7-10 amps. The chip is rated for 16 amps but with other limitations 7-10amps is a safe bet.
I've researched the IRFZ48N which handles 64 amps. I would like to change out the IRF530 for possibly 1, 2, 3, or more of the IRFZ48N's. First question, are there any major mods that would be required to run several of these chips? The circuit uses a 556 timer to drive the mosfet. Best I've been able to figure is that I might need a different value of resistor from the 556 output to each of the IRFZ48N's. Can someone clarify needed mods. Also, does anyone have any other inexpensive suggestions for a high current mosfet to integrate into this circuit (shown below). I can get the IRFZ48N for $1.75 from Mouser and less from Digikey so it's a nice option. I would like to be able to run over 50 amps with minimal heating with the Mosfets on a large headsink w/ a fan like one for a Pentium II CPU
Thanks for any help.
