sachin.kolkar
hi guys,
I m working on the DIMMER for resistive as well as inductive loads using PWM. i m using mikroc compiler . PWM output of the uC is used to control the firing angle of the triac, but my problem is that when i drive the triac through the MOC3041 then the output of the triac flickers .
i m using the 4MHz crystal for the uC, and tthe PWM frequrency is 250Hz.
can i rectify this by using 1MHz crystal oscillator, making the PWM frequency to 100Hz. If i use the 100Hz frequeny , it gives the 10ms a pulse.
any budy please help me ...
