PWM Electronic Control - Pulse width modulator for 30A 12/24Vdc
Use a standard 555 timer based PWM generator, and a couple of power transistors (or Mostfets) to boost the power handling capability.
ron, as I read it he means a PWM generator that can do 30 amps, input/output voltage are the same, between 12 and 24 volts DC. At 30 amps that's why I suggested looking into Mosfets, (no diode drop just a very low ESR) but there are many depending factors on what neutrino actually wants to do that will effect what the best choice is.
I often get burned. At about post #30 we find out it is 220AC to 12 to 24DC at 30A. I want to know long before post 30.
Ron. We're on post 2 or 3 at best. Lets keep the original poster in mind here please. EVERY original post must be treated as the first one. You're already derailing understanding by foretelling of a perceived intent of which none has been given.
We're here to do one thing and one thing only, to help to increase understanding, not to judge.
For input DC-voltage 12V or 24V.
Max current through the DC- engine 30A!
What kind of engine? What kind of control?
Will the control be provided manually (e.g. using a rotary or slider control, or switches) or by a microcontroller/PC ?
Is the engine/motor one having field coils (i.e. is it an inductive load) ?
DC-engine for 12V or 24V
And what kind of control? Speed control to both directions? Is the 30A current just an estimate (stall current)?
In general, you need an H-bridge that can handle the 24V and 30A. Do you wan't buy one or build it yourself?
Then you need the PWM signal. You can do this with analog circuit:
1) DC reference, triangle wave and a comparator.
2) 555 timer
You can also use a microcontroller to create the PWM signal.
What is the application? Is it a simple human operated machine or a more complex and automatic? Do you need accurate speed control?
