Noggin
My wife carved a pumpkin for a company contest last night. They weren't allowed to put a light bulb or a candle in it, so I threw this together in about two hours last night. The LEDs pulsate smoothly. Other effects could be added as well to make the LEDs flicker randomly, or whatever else you can come up with.
Few seconds of video: https://www.dropbox.com/s/v7w4u3jskt02jv7/2012-10-30 21.50.07.mp4
#include <xc.h>
__CONFIG(FOSC_RC & WDTE_OFF & PWRTE_OFF & BOREN_OFF & BODENV_25 & CP_OFF);
/* **** Global Function Prototypes **** */
/* **** Global Variable Definitions **** */
/* **** Local Definitions **** */
/* **** Local Function Prototypes **** */
/* **** Local Variable Definitions **** */
unsigned char table[] = {
0, 1, 2, 3, 4, 5, 6, 7,
8, 9, 10, 11, 12, 13, 14, 15,
16, 17, 18, 19, 20, 22, 24, 26,
28, 30, 33, 36, 39, 42, 46, 50,
55, 60, 66, 72, 79, 86, 94, 103,
113, 124, 136, 149, 163, 179, 196, 215,
236, 255,
* Created by :
* Date created : OCT 2012
* Description :
void main( void )
unsigned long long timer = 0;
unsigned char index = 0;
unsigned char count_direction = 1;
TRISBbits.TRISB3 = 0; // Set PWM pin as output
PORTBbits.RB3 = 0; // Turn on LEDs
CCP1CONbits.CCP1M = 0x0C; // RB3 set for PWM
PR2 = 0xFF; // Set period
CCPR1L = 0x00; // Duty to 0%
T2CONbits.TOUTPS = 0x07; // Set timer 2 prescaler
T2CONbits.TMR2ON = 1; // Enable timer 2 (used as time base for PWM)
while (1)
while (timer++ < 0x3FF) // Adjust this value to control how quickly the LEDs pulse
continue;
timer = 0;
if (index == 0)
CCPR1L = table[index++];
else if (index == sizeof(table))
CCPR1L = table[--index];
count_direction--;
else if (count_direction)
else
