Pull Down Resistor as an Input
pic_programm3r
Hi All,
I've been reading about pull down resistors and i was wondering what would be some examples of using a pull down resistor to read an input.
the first thing that comes to mind: Wiki
"pull-down resistors are used to hold the input to a zero (low) value when no other component is driving the input. They are used less often than pull-up resistors. Pull-down resistors can safely be used with CMOS logic gates because the inputs are voltage-controlled. TTL logic inputs that are left un-connected inherently float high, thus they require a much lower valued pull-down resistor to force the input low. This also consumes more current. For that reason, pull-up resistors are preferred in TTL circuits."
