Kryten New Member Nov 21, 2010 #1 Hi Does anyone know if there are an issue with DS18S20 talking to a uC in Proteus?
Kryten New Member Nov 21, 2010 #3 I forgot... Well the display is showing -00.5 deg no matter what i put in the ds18s20 (using code that others say work. Im going to change it a bit)
B bryan Member Nov 21, 2010 #4 Have you tried using the DS18B20 VSM module, are you sure the code you are using is for the "S" version of the Dallas.
Kryten New Member Nov 22, 2010 #5 I see that I have misread the code i have copied... It will only work with DS1820 as is. Minor changes and it should work with DS18S20.. Does anyone have one wire lib (or equal) for hitec c comp?
B bryan Member Nov 22, 2010 #6 WP100 on this board has done a lot of work on the DS18B20, however his project is in assembler. There is this one in C18 or CSS, should be easy to port over to hitec **broken link removed** Last edited: Nov 22, 2010
Kryten New Member Nov 23, 2010 #7 bryan said: WP100 on this board has done a lot of work on the DS18B20, however his project is in assembler. There is this one in C18 or CSS, should be easy to port over to hitec **broken link removed** Click to expand... Do you posses the skills needed? Im trying but cant say I got very far last night EDIT TI made a bobo I hav the DS18B20 NOT DS18S20 as i assumed Last edited: Nov 24, 2010
