Proteus ISIS Simulation Problem
TipTip
Hello Fellows,
Hope everyone here is in great health.
I need your help fellows, I have been asked the following Question:
"Write a program that ANDs the input logic levels available at the pins RB0, RB1,
RB2,RB3, and outputs the result to pin RA0"
I have done the coding to it using MPLAB IDE:
		processor 16f84A
			include    <p16f84A.inc>
			__config  _HS_OSC & _WDT_OFF & _PWRTE_ON
			ORG 	H'00'
			BSF		STATUS,RP0
			MOVLW	H'0F'
			MOVWF	TRISB
			MOVLW	H'00'
			MOVWF	TRISA
			BCF		STATUS, RP0
DOAGAIN		BTFSS	PORTB,0
			CALL	OUTPUT0
			BTFSS	PORTB,1
			CALL 	OUTPUT0
			BTFSS	PORTB,2
			CALL	OUTPUT0
			BTFSS	PORTB,3
			CALL	OUTPUT0
			CALL	OUTPUT1
			GOTO	DOAGAIN
OUTPUT0		MOVLW	H'00'
			MOVWF	PORTA
			RETURN
OUTPUT1		MOVLW	H'01'
			MOVWF	PORTA
			RETURN
			end
. And after compiling the coding, I have added the .hex file created to the circuit I simulated, but the problem is that the logic is not workig, i.e. if I make inputs RB0 to RB3 ANDed value is zero, the LED connected to the RA0 output lights up.
I have attached the .hex file, .asm file.
As for the proteus ISIS .DSN file it is here:
I hope I could find anyones help.
Thanks a lot and looking forward for your help
TipTip
  • CODE3.asm
  • LAb3HW.hex
When your bit test calls an OUTPUT0 it returns to the next statement
it shouldnt do that, otherwise it will always show OUTPUT1.
that should be obvious when stepping through it.
Tubos,
Thanks a lot. You made my day.
I hope you a nice and entertaining year.
+ rep to you too
TipTip
