programming
include<pic.h>
unsigned short mask(unsigned short num) {
switch (num)
case 0 : return 0x3F;
case 1 : return 0x06;
case 2 : return 0x5B;
case 3 : return 0x4F;
case 4 : return 0x66;
case 5 : return 0x6D;
case 6 : return 0x7D;
case 7 : return 0x07;
case 8 : return 0x7F;
case 9 : return 0x6F;
} //case end
void main()
int c;
int d;
TRISD=0; //
TRISB=0X00;
TRISC=0X00;
PORTC=0X02;
PORTC=0X00;
c=0;
while(c<100)
d++;
while(d=5000)
c++;
d=0;
PORTD=c;
PORTB=0X01;
_delay(5000);
PORTB=0X00;
i am a beginner in c programming..i am getting the continuous display,bt that runs very fast.how to correct this program?how i can give proper delay for that?
void main()
    int c;
    int d;
    TRISD=0;                           //
    TRISB=0X00;
    TRISC=0X00;
    PORTC=0X02;
    PORTC=0X00;
   c=0;
   while(c<100)
       _delay(100);      //<----new line here slows it down maybe too much
       d++;
       while(d=5000)
          c++;
          d=0;
          PORTD=c;
          PORTB=0X01;
         _delay(5000);
         PORTB=0X00;
That's an unusual control flow. I would call _delay() whenever you increment d.
void main()
    int c;
    int d;
    TRISD=0;                           //
    TRISB=0X00;
    TRISC=0X00;
    PORTC=0X02;
    PORTC=0X00;
   c=0;
   while(c<100)
       d++;
       while(d=5000)
          c++;
          d=0;
          PORTD=c;
          PORTB=0X01;
         _delay(5000);
         PORTB=0X00;
program is working..but how can we control the runing speed?
simple:
void main()
    int c;
    int d;
    int delaytime=50;   //NEW VARIABLE
    TRISD=0;                           //
    TRISB=0X00;
    TRISC=0X00;
    PORTC=0X02;
    PORTC=0X00;
   c=0;
   while(c<100)
       _delay(delaytime);      //<----new line here slows it down maybe too much
       d++;
       while(d=5000)
          c++;
          d=0;
          PORTD=c;
          PORTB=0X01;
         _delay(5000);
         PORTB=0X00;
To control speed you can either manual set delaytime variable or have 2 buttons for the user. When button 1 is pressed it adds 1 to the delaytime variable and when button 2 is pressed it minus 1 from delaytime variable...
Be sure to check the buttons inside the loop... not before the delay to get a better feel for the buttons.... Also dont forget to delay after a button press so it wont alter the variable to fast .
simple:
void main()
    int c;
    int d;
    TRISD=0;                           //
    TRISB=0X00;
    TRISC=0X00;
    PORTC=0X02;
    PORTC=0X00;
   c=0;
   while(c<100)
       d++;
       while(d=5000)
          c++;
          d=0;
          PORTD=c;
          PORTB=0X01;
         _delay(5000);
         PORTB=0X00;
i am a beginner i dont no much about c.is this program is correct?
It is correct.
While we're here, I would change the line:
       while(d=5000)
to read:
       if(d=5000)
Both while(d=5000) and if(d=5000) need to be while(d==5000) and if(d==5000).
bt replacing '=' with '=='
Error [800] D:\C PROGRAMS\inc display\display.c; 787. undefined symbol "__delay"
this error is coming.y?
If your original code was correct, it's "_delay", with one underscore, not "__delay" with two.
Details, details. Computers are unforgiving.
Ouch. I totally missed that. That's my punishment for using assembly for the past few projects.
It's amazing how quickly we forget these things. I find that if you switch it around so it becomes while(5000==d) it will give an error if you forget the second equals.
