program clarification
LIST P = PIC16F877A
#INCLUDE "P16F877A.INC"
__CONFIG _CP_OFF & _WDT_OFF & _XT_OSC & _LVP_OFF
cblock 20h
hibyte
lowbyte
temp
IRWaitCnt
msb,lsb,ones,tens,hund,thus,ss,sp,rr,tmp,tmp1,STORE,blink,hunds,tmp2,timer
endc
ORG 0X00
MOVLW 00H
MOVWF PCLATH
CLRF STATUS
GOTO main
org 04h
movwf temp
swapf STATUS,W
movwf STORE
clrf STATUS
GOTO ISR
retfie
lookup:
addwf PCL,F ;digit to be displayed
retlw b'00111111' ;'0'
retlw b'00000110' ;'1'
retlw b'01011011' ;'2'
retlw b'01001111' ;'3'
retlw b'01100110' ;'4'
retlw b'01101101' ;'5'
retlw b'01111101' ;'6'
retlw b'00000111' ;'7'
retlw b'01111111' ;'8'
retlw b'01101111' ;'9'
retlw b'01110111' ;'a'
retlw b'01111100' ;'b'
retlw b'00111001' ;'c'
retlw b'01011110' ;'d'
retlw b'01111001' ;'e'
retlw b'01110001' ;'f'
retlw b'00000000'
initport:
bsf STATUS,RP0
bcf TRISC,1
bcf TRISC,0
movlw 0x06
movwf OPTION_REG
movlw b'00000000'
movwf TRISD
bcf TRISB,5
movlw b'11010000'
movwf TRISB
bsf PIE1,TMR1IE
bcf STATUS,RP0
bcf PIR1,TMR1IF
bsf INTCON,GIE
bsf INTCON,PEIE
bsf T1CON,0
bcf T1CON,2
bcf T1CON,1
clrf TMR0
clrf TMR1L
clrf TMR1H
bcf PORTC,0
bcf PORTC,1
movlw b'11110000'
andwf PORTB,F
clrf PORTD
bsf PORTC,0
bcf PORTC,0
movlw 0x5f
movwf ss
bsf tmp,0
movlw 0x01
movwf ones
movlw 0x02
movwf tens
movlw 0x03
movwf hunds
movlw 0x04
movwf thus
clrf blink
return
mainline:
bcf INTCON,T0IF
bcf PIR1,TMR1IF
nop
btfsc PORTB,4
goto mainline
call start
xorlw 0FFh
btfss STATUS,Z
goto mainline
movlw 0FFh
movwf PORTD
bsf PORTC,1
call delay
bcf PORTC,1
movfw lowbyte
movfw hibyte
movwf tmp1
movfw lowbyte
movwf tmp
xorlw .1
btfss STATUS,Z
goto next1
goto chkOvr
next1: movfw lowbyte
xorlw .2
btfss STATUS,Z
goto next2
goto chkOvr
next2: movfw lowbyte
xorlw .3
btfss STATUS,Z
goto next3
goto chkOvr
next3: movfw lowbyte
xorlw .4
btfss STATUS,Z
goto next4
goto chkOvr
next4: movfw lowbyte
xorlw .5
btfss STATUS,Z
goto next5
goto chkOvr
next5: movfw lowbyte
xorlw .6
btfss STATUS,Z
goto next6
goto chkOvr
next6: movfw lowbyte
xorlw .7
btfss STATUS,Z
goto next7
goto chkOvr
next7: movfw lowbyte
xorlw .8
btfss STATUS,Z
goto chkOvr
goto chkOvr
chkOvr:
call convert
clrf lowbyte
clrf hibyte
goto mainline
chk: clrf tmp1
retlw 0Fh
start :
nop
incf tmp1,f
movlw .45
subwf tmp1,w
skpc
goto start
clrf tmp1
clrf TMR0
movlw 0x06
movwf TMR0
bcf INTCON,T0IF
call Wlow
call Whigh
btfsc INTCON,T0IF
retlw 0x0F
movfw TMR0
clrf TMR0
movwf timer
movwf temp
clrc
rrf temp,f
clrc
rrf temp,f
movf temp,w
subwf timer,
movlw 0x0c
movwf temp
nextBit : movfw timer
subwf TMR0,w
skpz
goto nextBit
btfss PORTB,4
goto waitlow
call Whigh
setc
goto clock
waitlow: call Wlow
clrc
clock: clrf TMR0
btfsc INTCON,T0IF
retlw 0x00
rlf lowbyte,F
rlf hibyte,F
decfsz temp,f
goto nextBit
movfw lowbyte
movwf temp
rlf temp,f
rlf hibyte,F
rlf temp,f
rlf hibyte,F
movlw 0x3f
andwf hibyte,F
movlw 0x3f
andwf lowbyte,F
retlw 0xff
Wlow : btfsc INTCON,T0IF
return
btfss PORTB,4
goto Wlow
return
Whigh : btfsc INTCON,T0IF
return
btfsc PORTB,4
goto Whigh
return
ISR:
btfsc INTCON,T0IF
; goto finish
goto mainline
btfss tmp,0
goto one
bcf PORTB,0
movfw ones
call lookup
movwf PORTD
btfsc blink,0
btfsc ss,5
bsf PORTB,0
rlf tmp,F
GOTO finish
one:
btfss tmp,1
goto ten
bcf PORTB,0
movfw tens
call lookup
movwf PORTD
btfsc blink,1
btfsc ss,5
bsf PORTB,1
rlf tmp,F
goto finish
ten: btfss tmp,2
goto hund1
bcf PORTB,1
movfw hunds
call lookup
movwf PORTD
btfsc blink,2
btfsc ss,5
bsf PORTB,2
rlf tmp,F
goto finish
hund1: btfss tmp,3
goto thuds
bcf PORTB,2
movfw thus
call lookup
movwf PORTD
btfsc blink,3
btfsc ss,5
bsf PORTB,3
rlf tmp,1
goto finish
thuds: btfss tmp,4
goto finish
bcf PORTB,3
clrf tmp
bsf tmp,0
goto finish
finish:
swapf STORE,W
movwf STATUS
swapf temp,F
swapf temp,W
bcf INTCON,T0IF
bcf PIR1,TMR1IF
clrf TMR1L
clrf TMR1H
movlw 0xf0
movwf TMR1L
movlw 0xee
movwf TMR1H
retfie
return
convert:
movf tmp,0
movwf lsb
movf lsb,0
movwf ones
bcf ones,7
bcf ones,6
bcf ones,5
bcf ones,4
call ISR
return
delay
movlw 0x05
movwf rr
back2: movlw 0xff
movwf sp
back decfsz sp,1
goto back
decfsz rr,1
goto back2
return
main
call initport
goto mainline
end
hai,
this prrogram is mainly used for interfacing the remote controller and 7sedment dspy..i used timer1 for the display and timer0 for decoding the IR code...bt nw am facing a program that i didnt got the proper out...this projct s for changing the display using remote...wl u pls help me to getting the output?????
