Problem with PORTB port change interrupt
zhaniko93
   LIST P=16F628A, R=DEC    ; Use the PIC16F628 and decimal system
   #include "P16F628A.INC"  ; Include header file
   __config  _INTRC_OSC_NOCLKOUT & _LVP_OFF & _WDT_OFF & _PWRTE_ON & _BODEN_ON & _MCLRE_OFF
   errorlevel -302
   goto Start
   org 0x4
   bcf INTCON, RBIF
   retfie
Start  movlw 7
   movwf CMCON
   bsf INTCON, RBIE
   bsf INTCON, GIE
   clrf PORTA
   clrf PORTB
  banksel TRISA
   movlw b'11110000'       ; RB3(PWM)=0
   movwf TRISB
  banksel PORTA
nop
goto $-1
        END
when simulating in osohsoft Pic simulator IDE,everything goes fine untill I put PORTB, 7 port on 1, interrupt happens and then after retfie, interrupt happens again! and again, and again in spite of I change from 1 to 0 or not, why?
missing portb read
Replace your interrupt handler code with:
goto Start
   org 0x4
   movf PORTB,w ; you must read PORTB upon Int-on-chg
   bcf INTCON, RBIF
   retfie
Quote from section 5.2 of the datasheet:
Clear the
interrupt in the following manner:
a) Any read or write of PORTB. This will end the
mismatch condition.
b) Clear flag bit RBIF.
A mismatch condition will continue to set flag bit RBIF.
Reading PORTB will end the mismatch condition and
allow flag bit RBIF to be cleared
I forgot that:
mismatch condition.
Thanks Mosaic!
