Honoured members,
As I am a newbie, I would shut my mouth, but this matter with 89s52
is very important to me , so please try to concentrate on it instead of whether P0 is collector or drain open!
Thank you !!!
And now here is the problem
Hello!
I "think" i have programmed a At89S52(at leat the flash is ok), but the logic levels at my ports are in the same state whether i use power on reset circuit or not! (it is not follwing the assembler code)!
I used standard 8051 POR circuit(8.2k + 10uf)!
Can you tell me if there are other values of these components for 89S52, or my chip has not been programmed?
Could it be burned?
Please reply me here or at rellutzu_1981@yahoo.com!
Thank you for your time!
EA should be 0v or 5V connected???
Yes, I can read the state of my flash, and the oscilator is the same one
i use in programming!
I added a reset button, but still the same problem : states at my ports are the same!
All of my ports are in the same state!
There is one more thing : just one of my external quartz has a voltage on its pin(in operantig mode). The other one doesn't!
Than how could I was able to program the flash?
Thank you !!!
Hello!
Could it be burned?
