Problem with 2 channels read reading
altra22
Problem with 2 channels reading A/D
Hi
iam trying to read 2 inputs from A/D
temperature and voltage the problem with update values in lcd
the temp is working perfect but the voltage , i must do hard reset to the Board to update the value of voltage
here is my code
#include <16F876a.h>
#device ADC=10  // Use 10 bits
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use delay(clock=20000000)
#include <lcd.c>
#use fast_io(B)
float y,i,x,value;
void main()
lcd_init();
   output_b(0x00);
   set_tris_b(0x00);
   // Setup A/D
   setup_adc_ports(RA0_RA1_RA3_ANALOG);  // Only RA0 as analog input
   setup_adc(ADC_CLOCK_DIV_32);  // Divide clock by 32
   while(1)
   set_adc_channel(0);
   delay_ms(100);
      i = read_adc();
      x= (i*5/1023)-5 ;
      // secound channel //
      set_adc_channel(1);
      delay_ms(100);
      value = read_adc();
      y = 5*value*100/1023;
    printf(lcd_putc,"Volt is %f \nTemp is %f   ",x,y);
Sorry for read reading thingy i cant change the title
regards
