sarang1_in
Hi all,
I am facing a problem while debugging the code. The following error is comming and it is jumping to disassembly
Error message is
*** 65: access voilation at 0X001B: no 'execute/read' permission
This location is Timer 1 interrupt routine.
My code is as follows
Please tell me where I am wrong as I am stuck to it solving from last so many days and not getting any solution.
Thanks in advance.
Error message is
/*include header files*/
#include<stdio.h>
#include<reg52.h>
#include<math.h>
/*function declerarion*/
//void chkproto(*char);
//void sendserial(unsigned char transmitchar)
/*variable declearation*/
data char recv,Dir,mode,Stat;
bit run,stop,query,queryp,setp;
data char recv_cnt,Step_mode,Steps_no1,Steps_no2,Steps_no3,Vel_1,Vel_2;
unsigned int data Delay;
data int Steps,Vel,Iref,Iidle,ramp_up,Delay_Row,ramp_dn,ramp_step;
code int DLY[4][3]={{5000,2000,200},
{2000,1000,100},
{1000,500,50},
{500,100,10}};
code char stepbit1[]={9,8,10,4,6,3,1};
code char stepbit2[]={8,4,3,1};
char data pos_ack[]={':','0','1','R','P','X','E'};
data char Querr_device_no,Profil_no,sencnd,sendchr,send_q;
data char rec_buf[17],send_buf[17];
static char i;
sbit DE =P3^2;
void SerialInt(void)interrupt 4 using 1
if(RI)
{ RI = 0;
recv = SBUF;
if( recv == ':')
recv_cnt = 0;
rec_buf[recv_cnt] = recv;
else
recv_cnt++;
if ( recv_cnt >= 16)
recv_cnt = 0;
else
if ( recv == 'E'&& rec_buf[(recv_cnt)-1] == 'X')
if (recv_cnt == 15)
if ( rec_buf[0] == ':'&& rec_buf[3] == 'R')
{ run = 1;
Dir = rec_buf[4];
Step_mode = rec_buf[5];
Steps_no1 = rec_buf[6] * 1000;
Steps_no2 = rec_buf[7] * 100;
Steps_no3 = rec_buf[8] * 10;
Steps = Steps_no1+ Steps_no2+ Steps_no3+ rec_buf[9];
Vel_1 = rec_buf[10] * 100;
Vel_2 = rec_buf[11] * 10;
Vel = Vel_1+ Vel_2+ rec_buf[12];
Profil_no = rec_buf[13];
else if (recv_cnt == 6)
if ( rec_buf[0] == ':'&& rec_buf[3] == 'S')
if ( rec_buf[0] == ':'&& rec_buf[3] == 'Q')
Querr_device_no = rec_buf[1];
send_q = 1;
else if (recv_cnt == 13)
if ( rec_buf[0] == ':'&& rec_buf[3] == 'P')
{//i++;
else if (recv_cnt == 7)
if ( rec_buf[0] == ':'&& rec_buf[3] == 'Y')
{//i++;
if(TI)
TI = 0;
sencnd++;
if ( sencnd == sendchr)
DE = 0;
else {
SBUF = send_buf[sencnd];
void Timer0(void)interrupt 1 using 2
switch(Stat)
{case 1:
if(mode=='F')
{if(Dir=='C')
{if (ramp_up != 0)
P1 = (P1 && 0xF0) || stepbit1[i];
i++;
if(i == 8)
i = 0;
else if(Dir=='A')
{if(ramp_up != 0)
{P1 = (P1 && 0xF0) || stepbit1[i];
i++;
if(i==8)
i = 0;
else if(mode=='H')
{if(Dir=='C')
if (ramp_up != 0)
i++;
if(i == 4)
i = 0;
else if(Dir=='A')
{if (ramp_up != 0)
i++;
if(i==0)
i = 0;
Steps = Steps-1;
ramp_up = ramp_up-1;
if(ramp_up==0)
Stat = 2;
else
{Delay = Delay - DLY[Delay_Row][3];
if(Delay < DLY[Delay_Row][2])
Delay_Row = Delay_Row + 1;
TL0 = (Delay & 0xFF);
TH0 = ((Delay >> 8) & 0xFF);
break;
case 2: if(mode=='F')
{if(Dir=='C')
{if(Steps<= ramp_step)
i++;
if(i == 8)
i = 0;
else if(Dir=='A')
i++;
if(i==8)
i = 0;
else if(mode=='H')
{if(Dir=='C')
i++;
if(i == 4)
i = 0;
else if(Dir=='A')
i++;
if(i==0)
i = 0;
Steps = Steps-1;
if(Steps <= ramp_step)
{Stat = 3;
ramp_dn = ramp_step;
//timer0 = Delay;
break;
case 3:
if(mode=='F')
{if(Dir=='C')
{if(ramp_step != 0)
i++;
if(i == 8)
i = 0;
else if(Dir=='A')
{if(ramp_step !=0)
i++;
if(i==8)
i = 0;
else if(mode=='H')
{if(Dir=='C')
{if(ramp_step !=0)
i++;
if(i == 4)
i = 0;
else if(Dir=='A')
{if(ramp_step != 0)
i++;
if(i==0)
i = 0;
ramp_dn = ramp_dn-1;
Delay = Delay + DLY[Delay_Row][3];
if( Delay > (DLY[Delay_Row][1]))
Delay_Row = Delay_Row - 1;
//timer0 = Delay;
Steps = Steps-1;
if(Steps <= 0)
{Stat = 4;
//set timer2 =5000;
TR0 = 0;
break;
default: break;
void Timer2 (void) interrupt 5 using 3
{ if(run == 1)
{TR2 = 0;
ramp_step = 20;
if((ramp_step*2) < Steps)
ramp_step = (Steps/2);
ramp_up = ramp_step;
//set timer with delay
Delay_Row =1;
Stat = 1;
if(Stat == 4)
{ TR2 = 0;
Iref = 0x7f;
/***************************Timer Isr Ends Here*********************************/
void sendserial(char);
void init_run(void);
//void init_stop(void);
//void send_response(void);
void main(void)
P1 = 0x00 ; //Initialise P1.0 to P1.3 used as output &
//Initialise P1.4 to P1.7 used as input
SP = 0x50;
SCON = 0x50; //Set Serial IO to receive.And select mode1
TMOD = 0x21; //configure timer for the correct baud rate
TH0 = 0x00;
TL0 = 0xF7;
TH1 = 0xFD; //TH1: reload value for 9600baud @11.059MHz
TL1 = 0xFD; //TH1: reload value for 9600baud @11.059MHz
TCON = 0x00; //Set timer to not running
T2CON= 0x00;
T2MOD= 0x02;
// TI = 0; //clear transmit interrupt flag
// RI = 0; //clear receive interrupt flag
// TR0 = 1; //start timer 0
TR1 = 1; //start timer to Receive
TR2 = 0;
IE = 0xFA;
ET0 = 1; //enable timer 0 interrupt
// ET1 = 1;
EA = 1; //Enable global interrupt
ES = 1; //Enable serial interrupt
PS=1;
DE=0;
while(1)
if(run)
sendserial('R');
init_run();
if(stop)
sendserial('S');
//init_stop();
if(query)
sendserial('Q');
//send_response();
void sendserial(char command)
int j;
*(pos_ack+3) = command;
sencnd = 0;
sendchr = 7;
for(j=0; j < 7; j++)
*(send_buf+j) = pos_ack[j];
DE = 1;
TI = 0;
void init_run(void)
run=0;
TH2=0x13;
TL2=0x88;
Iref=0xff;
Delay=5000;
TR2=1;
Stat=1;
/*void init_stop(void)
Thanks in advance.
