Problem in progaming Pic12f675
deepa.malagi
I am unabal to program the ic properly .In debug mode after programming when i press run it showing error message as
PK3Err0040: The target device is not ready for debugging.
Please check your configuration bit settings and program
the device before proceeding.
my configuration bits are
oscillator = internal rc on clk
master clear enable = external
rest all are off
and I am using HI-tech c compiler
and my code is
#include<pic.h>
#define OUTPUT_SIGNAL 0x00
#define INUPT_SIGNAL 0x02
#define GPIO_OUTPUT_SIGNAL (GPIO&0x01)
#define GPIO_INPUT_SIGNAL (GPIO&0x02)
#define LED GPIO4
unsigned char INTR_FLAG = 0;
void configuretion (void);
void interrupt slow_led (void);
main()
//configuretion();
//OPTION = 0b01000111;
TRISIO=0x00;
while(1)
GPIO=0x22;
OPTION = 0b01000000;
ANSEL = 0; //adc off - digital in/out
CMCON = 7; //turns comparators off
GPIO = 0; //all outputs set to 0
TRISIO = 0b00000100; //all outputs except pin GPIO2
INTCON = 0b1001000; //external interrupt enabled on GP2
if(INTF) //check external interrupt flag bit
INTF = 0;
LED = 1;
INTR_FLAG = 1;
while(INTR_FLAG)
if((GPIO & 0x04) != 1)
INTR_FLAG = 0;
please anybody help me.
problem in programing Pic12f675
thank you for reply
I am running my program in the program mode
but I am not getting proper answer by micro controller
my code is
#include<pic.h>
#define LED GPIO4
main()
TRISIO = 0x00;
TRISIO = 0x04;//GPIO.3 = input
GPIO1 = 1;
//IOC = 0x04;
//GPIE = 1;
//GIE = 1;
while(1)
//GPIO,GPIO0= 1;
GPIO = 0x01;
GPIO = 0x03;
problem is I want GPIO 3 as input pin
if i comment the if statement then I am getting GPIO as 0x03.
But when i remove the comment on if I am getting GPIO as 0x0C.
why i am not getting the problem in my code.
please help me.
