I was building amplifier based on chip TDA 7240A, but encounter a weird noise.
It only happen when i connect to my music source (netbook), but doesn't happen that when i directly connect to my speaker unit (without amplifier).
It notice when i'm not using AC (use battery power) on my netbook, that noise doesn't happen. This also same for my previously build discrete amplifier.
But if i use any commercial brought amplifier, no such problem. So i guess need to incorporate something to make this noise disappear ?
hm.... i decided to record the noise using my netbook's in-built mic, so its not good quality. Attached in following link :
Any advise how to remove such noise from my amplifier (discrete amp noise is different)?
At the first 4 second, it was the ambient noise (the amplifier is turn off) and was raining (doesn't sounds like raining is it my mic sucks).
After the first 4 second, i turn on the mic amplifier, with AC powered netbook as input. (without any music on, just plug in), the noise is obviously heard, but the pitch is different in real world (my lousy mic......) Is it oscillation ?
About at 12 second, I plug out the AC charger, thus on battery powered only. That makes the noise goes away, and speaker is nice with just a little hum (acceptable and can't heard by the mic).
At 22 second, I plug in the AC charger into netbook again, thus the noise came out again. About at 28 second, I remove the input TRS jack, thus no noise heard. At 30 second, I plug in the input jack to netbook, thus making noise again.
