I bought a electronic transformer initially meant for halogen bulb lighting.
Its 60VA at 12V, figured it will be cheaper then buying a transformer and more efficient. Was cheap to about $8US. It seems its an ordinary SMPS
I also bought some digital multimeters which I want to dissassemble and use as voltage/ampre meters for $2US each, they were dirt cheap.
I want to use the above in a LM317T regulated power supply. But I tried it out today and it don't work.
When I put a bridge rectifier on the SMPS. I measure 6vdc. Stick a 1000uf cap on it and it measures 12VDC, exactly what I need. Then I connect the LM317T on it, then things go all weird. Voltage jumps between 2vdc and 12vdc every second on the output of the LM317T and the input of the LM317T. I know the LM317T circuit is working perfect becauseb I'm using it on a transformer power supply no problems.
Now why is the voltage jumping up and down. Is this what u guys refer to ripple on SMPS ? How do I get rid of it so I can actually use this thing with a voltage regulator. I tried sticking on a smaller cap then the voltage doesnt even get close to 12vdc.
What is my problem
What is my problem
