power supply for micro controller
Parth86
I don’t know how the component are connected in this power supply please any one help me to understand how the component are connected
This PCB contain two circuit
Power supply
Programmer circuit
I have attached image
Power supply circuit component
12v battery connected to battery connector . battery connector connected to on/off switch. On / off switch connected to bridge rectifier IC w104br , after rectifier IC don’t know which one capacitor c10 or c13 connected to the output of rectifier and voltage regulator IC 7085 connected to output of filter capacitor
First I don’t know which one is one capacitor is connected C10 or C13?
The data sheet says the "recommended" cap values are 0.33uF on the 12v side and 0.1uF on the 5v side
This should give you a clue.... Have you a multimeter??
actually I searched for power supply and I got this Image I wantto make power supply myself In this circuit I don't know which one capacitor is connected first I want to make layout first after that I want to soldering on PCB
Straight from the data sheet of an LM7805 regulator... You start with this..
battery+battery connector+on/off switch+bridge IC+1000/60 Electrolytic Capacitors+0.33uF Ceramic Capacitors+7085 IC+ 0.33uF Ceramic Capacitors
now I have led,resistor , reset switch , jumper, how they connect together
Are you making the board in your first post???
bridge IC+1000/60.. What is this.. If it's battery powered why do you need a bridge? This is so you can plug in a wall adapter that outputs 12ac.
check out this its paper work
12v dc battery +battery connector+bridge IC+ capacitor+voltage regulator IC+capacitor+variable resistor+jumper (5 volt for controller+ 5v for programmer circuit )+reset switch+current limiting resistor +LED indicator
hello again , I need power supply circuit for micro controller and sensor circuit. I have 12v dc battery and I need 5v for micro controller and 5v for sensor circuit
component
battery- 12v dc
battery connector
switch- on/off
bridge Ic- 2w10G
C1 capacitor- 1000/25 volt Electrolytic Capacitors
C2capacitor - 22 pf/50 volt Ceramic Capacitors
regulator Ic-708 5v/1amp
C3 capacitor - 22 pf/25 volt Ceramic Capacitors
R1 variable resistor
reset switch
jumper J1
jumper J2
R2fixed resistor
indicator - LED
I have attached Image
The 7805 needs to have the ground pin connected... For what purpose is the variable resistor... What are the J1 and J2 for.
This is all you need to supply 5v from a 12 v battery
J1 and J2 are jumper J1 is used for micro controllers supply and J2 is used for sensor supply . variable resistor is used adjust the resistance.
see post #1 I am trying to make that type of power supply
