Power Inverter "One World" P-2000C Problem
Athhos
Hi people.
I'm having some problems to identify the fault of my inverter. It was mounted in my caravan and it stopped working from a moment to another. Don't know if anyone knows this model of inverter. I checked every fuses and mosfets. All seems to be okay. About IC's it uses the pulse 3525AN and quad AMPOP 324. P mosf 450lc and 50N06. Sorry about my english but i really need help.
Does the failure happen when you are driving or anytime.
If it happens when you are moving I would suspect a bad solder connection or a loose connection.
Sorry. I wrote that on my android and smartwriting was not in english, was in portuguese. I meant I checked every solders, caps or "components" of being bad. The unit gone bad during when stopped driving. The fault bip appeared and when I saw the led was bright to. Since that no good news. I contacted oficial suppliers and no answers until now.
Sorry for the english.
Regards,
Sérgio.
about inverter p-2000c ... change IC SG3525AN , pin number 10 is the shutdown, the shutdown function is always on shutdown, replace this IC to go back in normal operation of power inverter :)
Hi people.
Hi people.
