Johnson777717
Good day all. I'm wondering if someone wouldn't mind helping me with some math, or at least give me a push in the right direction. I realize that a lot of folks don't like to just give the answer because it defeats the purpose of learning. With that said, can you please help me to learn how to calculate this.
Here's what I want to do:
1. I have a + 12 V and Ground regulated supply.
2. I want to create a potential divider from the 12 volt supply in order to reduce the voltage to 9V.
3. I want to be able to supply only 560mA for the 9V supply (the 12 volt supply will be capable of approximately 1 amp total with a fan already drawing a max 200mA, which leaves me 800mA or so to play with.)
So far, for a potential divider, I've calculated:
V2 = (R2 / (R1 + R2)) * V1
where V2 is the output voltage, V1 is the input voltage.
I've also discovered that I need a R1:R2 ratio of 1:3 in order to obtain a 9V output for V2.
I'm stuck on how to provide current limiting to approximately 560mA...therefore this is my question...
How do I limit the current (or calculate for) to approximate 560mA using a ratio of 1:3?
Thank you very much! I appreciate your help.
Thank you
Thank you
