AtomSoft
Hey guys need quick info but take your time. I mean i have a quick question.
from my datasheet:
Does that mean i cant use my 20MHz crystall with PLL? Or does it mean i cant use the OSC = HSPLL with more than a 10MHz crystal?
Also if it means that i can still use OSC = HS and use a 20 Mhz clock. Can i use the PLL bits? So like a software PLL.
from my datasheet:
2.5.1 HSPLL OSCILLATOR MODE
The HSPLL mode makes use of the HS Oscillator
mode for frequencies up to 10 MHz. A PLL then multiplies
the oscillator output frequency by 4 to produce an
internal clock frequency up to 40 MHz. The PLLEN bit
is not available in this oscillator mode.
The PLL is only available to the crystal oscillator when
the FOSC3:FOSC0 Configuration bits are programmed
for HSPLL mode (= 0110).
