please measure inductance of any 6-12v reed relay coil for me
epod
I need an approximate ball park inductance value of any 6 or 12 volt reed relay coil, one that is designed for the glass bulb and contacts
not the little black plastic DIL type
I know that here are many variables to this value, make, wire size etc etc
but if you have an inductance meter and a reed relay in your junk box could you please tell me what you read.
also if you could tell me what voltage your coil is for, and maybe the resistance
this information would be appreciated
thanks
this style of relay coil I am interested in being measured here
NOT this type
The realy you showed looks like a PCB mount. I thought you wanted a non PCB type. Second, why do you care about the inductance? The relay uses DC voltage.
hi
gee that was quick I just posted a link to the little DIL type that I dont want checked
yes the one thats in the link could be put on a pcb, but thats the style of coil that I am interested in
why i need the inductance value is I need a pick up coil for a project , I need something greater then 1MH, but I would prefer something larger.
I can wind one but if a reed relay coil inductance value is bigger
I will give it a try.
The actual value of the coil does not realy matter, its only function is a magnetic pickup
and a reed relay coil would be nice and usefull given its size vs inductance
in a small package.
Most 1MH chokes have very little wire in them, and the inductance is boosted by a chunk of ferrite.
I need lots of wire and I think a RR coil should be ok, I dont have an inductance meter.
I have one that looks like the little green one (but it is blue :) )DCR = 1050Ω, Inductance = 267mH as measured on a **broken link removed**
