please help!!!!!!! (title says nothing about topic)
batman
I would like a flash bulb circuit, but that is activated either by sound or momentary pushbutton. The flash should have the possibility of being triggered many times in one second, but the normal will be about twice a second. Every time i tap the button or a sound is heard, the flash should occur. Basically a use-determined strobe
Can I somehow modify a strobe light or camera flash design?
many thanks
many thanks
Sound triggered flash circuits are quite common, a quick google search produced 14 hits, one of which was here .
However, if you want quick recharge times you will have to either use a strobe, or seriously upgrade the charging circuit in a flash gun. Another concern with a flash gun is the life of the tube, camera flash tubes are only designed to last a fairly low number of flashes (compared with strobe tubes).
batman said:
how would i adapt an off the shelf strobe light to perform ths function i am looking for
You'll have to rip one apart and see if you can locate and figure out what the trigger circuit is. Have the strobe running at say a couple hundred Hz and go try and find how the square wave is generated. If you can do that, you can likely disconnect the original driver circuit and kluge in your own driver. Be sure and use the power supplies that are powering the strobe.
