I urgently need to replace a 1 megohm 20 watt pot with the 1-10v analog output from a plc. The pot is on the dimming circuit of an electronic halogen transformer.
Should I be using a digital pot? Anyone have a circuit for this??
I dont have the circuit and the oem is not much help..
Maybe Im doing this the wrong way...
My goal is to use a PLC output to dimm a 71w 12v mr16 halogen bulb using a softstart electronic transformer (120>12v).
The transformer I am looking at has a blue loop of wire that you can cut and insert a 1megohm 20w pot to dimm the electronic transformer.
My other option is to modify the 120v going into the electronic transformer with a pwm type dimmer but I have not been able to find a pwm that will accept a 0-10v or 4-20ma control.
Im going to be building a lot of these..
Any ideas??
Thanks for the input!!
This wouldnt control the firing angle of a triac, it would be either ON or OFFOk I had a stupid moment... Its not a 20 watt pot
Its just a 1megohm pot with hardly any current on it. I hooked everything up, cut the blue loop of wire where the pot goes and measured between the hot side of the loop an nutral and I get 64vac, so im guessing that the 1megohm pot reduces the ac voltage from 64vac to 0vac which i think is the feed to a triac??
What about something like this?
I would just have to drive it with a 16ch cmos
