Hello Gurus!
I have build a JDM programmer, and I am able to program 16F84 & 628 chips without problems.
But I could not program 877A. On the JDM programmer site, it tells JDM can program 877(A?), but cannot use the default schematic - I have to build an adapter.
http://www.jdm.homepage.dk/newpic.htm
It does not give detail about how to build the adapter (i.e. pin-mapping) for 877A, so I try to use its In-Circuit Serial Programig (ICSP) function.
http://www.jdm.homepage.dk/icsp.htm
Following the instruction, I linked the 5 pins (MCLR,Vdd,Vss,RB6,RB7) to the 877A, but it didn't work. I got "Verify failed ar address 0x00000", normaly it means the write was unsuccessful.
I now have the following questions -
1) Have you programed 877A using JDM and/or ICSP? How do you do it?
2) How (where) should I connect the other pins of 877A (i.e. ground, 5V, clock, etc)? I ONLY connect these 5 pins to the programmer, other pins is not connected to anywhere, but I suspect I could be wrong.
3) Where can I find information about how to build JDM/16F877A adapter?
Thank you very much!!!
Michael
Michael
