Only have a small understand of PIR modules, so need some general information. I know they are three leads, +5volts, ground, and output. Output is either high or low when it detects.
Haven't been able to determine if two modules mounted close together, but angled so their field of detection only overlaps a little, will interact or confuse each other (false detection). The idea would be to pan the sensors until both detect the intruder (feline), and activate the deterant. When nothing is detected the sensors will rotate back to a home position.
Also don't know the effects of moving the sensors on detection. Will it need to be stationary to get a accurate detection, or will it work the same while in motion. I've only seen where they are mounted in a fixed position (alarms and security lights).
How much influence does sunlight have on these sensors. Only outdoor uses I've seen were motion lights, so suspect that daytime isn't a good time, which is okay.
