Piezo transducer extreme current
Nicolaii
I am doing a project in which i need to power piezo transducer with 140 kHz ~20V signal. When I`m powering piezo with generator it only takes 6mA. But when I try to power piezo with my circuit it takes more than 1A. When i place resistor it gets hot and circuit lose power. Where is the problem?
Maybe you could give me advice of alternate ways to power piezo with such a signal?
AnalogKid
Most Helpful Member
Is this your circuit?
How much current is available at the 20 V source?
What is the value of L1?
Do you know why L1 is in the circuit?
Manufacturer / part number for the transducer?
ak
Tony Stewart
Most Helpful Member
Nicolaii get the RLC Nomograph and look up impedance at resonant f and ask yourself , does f match source and what is impedance of the switch and why does this lower Q in a shunt tank. Try a linear bias current sink sine wave at resonant f instead of a switched square wave and don't saturate L. Add plastic C if f is fixed.
chemelec
Why 140 KHz?
Will your piezo even operate at that Frequency?
And you also can't hear it.
spec
Most Helpful Member
Hi Nicolii,
give the circuit below a try.
spec
dr pepper
Most Helpful Member
Yes 140kc is very high.
Increasing the inductance of the inductor will reduce current flow and 'volume'.
chemelec
Which Piezo are you using?
Most Piezo's have a Limited Frequency range of reproduction.
Very FEW of them will do 140khz.
EE World Online Articles
Loading
