PICBasic Pro
surferdude89
I'm a starter in picbasic language
I tried a simple program but my PIC is unable to supply the 5V accordingly
DEFINE OSC 4
TRISC = %00000010
PORTC = 0
START :
PORTC.0 = 1
IF PORTC.1 = 1 THEN
PORTC.4 = 1
ENDIF
GOTO START
.......pls give me advices on it~~
DEFINE OSC 4
TRISC = %00000010
PORTC = 0
START :
PORTC.0 = 1
IF PORTC.1 = 1 THEN
PORTC.4 = 1
ENDIF
GOTO START
Whats PORTC.1 connected to.?
You are testing for a high.
On PORTC.4 you should have a 220R in series with a led.
PORTC.1 is connected to my IR Sensor output, i measured the output of 3V when not reflected and around 0.7V when the signal is reflected.
but now even my PORTC.0 do not supply 5V to my circuit, what could be the problem? is the code wrong?
i did the circuit seperately by supplying 5 volt to my circuit and then measure the output of the sensor thru an op amp which is 3V
but now i wanted to use the PIC to supply 5V to the circuit but... >.<
I would like to help, but I dont understand your explanation.:)
Do you have a simple drawing you could post.?
What circuit are you trying to supply the 5Volts too.?
sorry for the explanation, let me put it tis way, i wan my PIC to supplied 5V(high) to a single pin(for example PORTC.0) so shud my program write tis way?
TRISC = %00000000
PORTC.0 = 1
TRISC = %00000000
PORTC.0 = 1
That should set PORTC.0 high. about +4V
Are you sure that the PIC is running.?
Do you have the MCLR connected correctly.
Is the crystal oscillator working.
There is voltage supply at Vss, the MCLR is connected, but how to i check whether my crystal is working correctly?
Checking an osc is not easy without an oscilloscope, you could try another crystal. Do you have any low vlue capacitors connected from the xtal pins to 0V.?
If you are using a prototype board, sometimes the xtal will not oscillate.
The PICbasic program you have posted should set the PORT pin.
As ALLVOL has suggested are you sure the prommer is writing the program to the PIC.?
Try this program,
TRISC = %00000000' all outputs
START :
PORTC= 255' all pins high
GOTO START
END
Lets know what you get.:)
ericgibbs thx for the help! now i tin i get the meaning
i always put PORTC = 1 and wondering y only 1 pin is high
now i know need to put PORTC = 255 :p
anyway thx for the help
