Hi guys I'm using a PIC32MX795F512L to write to a 320 x 240 ILI9325 LCD screen.
The program is (mostly) working fine and I am getting about 30 FPS when writing from the double buffered memory area using PMP and DMA.
The problem is when I try to write a single value to the whole screen, rather than writing from the double-buffered memory area.
First, here's my code for the successful PMP/DMA write from the double-buffered memory area:
Basically, I set up the 2 DMA channels. Channel 1 is set to go after channel 0 finishes. Both of them copy from the LCD_Buffer_1 to PMDIN (the PMP register) for a total of 60800 bytes per DMA channel.
The problem comes if I want to write the whole screen with a single value.
Using the exact same code, except I change the DmaSetChnTxfer code to:
it doesn't work. It fills about 10 pixels (some are the background color, some not) and then stops transferring through the PMP and the DMA channel doesn't finish.
With this function I am trying to fill the screen with 'BackgroundColor' up to an amount 'pixels'. There are 2 bytes per transfer (16 bit PMP).
As far as I can tell it should work fine.
So yeh basically just wondering if anybody more experienced than myself (I'm only just making the leap from assembler to C) can see why this bit of code doesn't work as it should?
void LCDWriteBuffer()
SetWindow(0,0,189,319); // Sets the memory (display) area on the LCD to write to
// Open the desired DMA channel. Priority 0/channel 0, priority 1/channel 1.
DmaChnOpen(0, 0, DMA_OPEN_DEFAULT);
DmaChnOpen(1, 1, DMA_OPEN_CHAIN_HI);
// set the transfer event control: what event is to start the DMA transfer
DmaChnSetEventControl(0, DMA_EV_START_IRQ(_PMP_IRQ));
DmaChnSetEventControl(1, DMA_EV_START_IRQ(_PMP_IRQ));
// set the transfer parameters: source & destination address, source & destination size, number of bytes per event
DmaChnSetTxfer(0, LCD_Buffer_1, (void*)&PMDIN, 60800, 2, 2);
DmaChnSetTxfer(1, LCD_Buffer_1+30400, (void*)&PMDIN, 60800, 2, 2);
LCD_RS=1;
// once we configured the DMA channel we can enable it
// now it's ready and waiting for an event to occur...
DmaChnEnable(0);
// force the first transfer to get the PMP and DMA started
DmaChnForceTxfer(0);
DmaChnSetTxfer(0, (void*)&BackgroundColor, (void*)&PMDIN, pixels, 2, 2);
DmaChnSetTxfer(1, (void*)&BackgroundColor, (void*)&PMDIN, pixels, 2, 2);
