hello guyz
I had written a program to read and write to the EEPROM through the SPI communication ports
fortunately I was able to read from the eeprom but the problem is that i could not write to it
I've tried the following :
1) put some delays between writing and reading from the EEPROM
2) read the status register on the beginning of the program it was 0x8C and after the write enable it is 0x8E which means that write enable lach is on but the write protection is enabled and the block protection*
3) after initializing the status register t0 0x00 still the value of the register is 0x8C
* status register (WPEN X X X BP1 BP0 WEL WIP)
25lc640 data sheet
25lc640 data sheet
// the last version of EEPOM in C modified on 28-11-2010
#include<pic.h>
__CONFIG(INTIO & WDTDIS & PWRTDIS & MCLRDIS & UNPROTECT & UNPROTECT & BORDIS & IESODIS & FCMDIS);
// Delay Function
#define _delay_us(x) { unsigned char us; \
us = (x)/(12000000/4000000)|1; \
while(--us != 0) continue; }
void _delay_ms(unsigned int ms)
unsigned char i;
do {
i = 4;
do {
_delay_us(164);
} while(--i);
} while(--ms);
void main (void)
unsigned char x=0x00,z=0x00,y=0x00,add=0x01,endadd=0xff;
TRISC7=0; // SERIAL OUTPUT
TRISC6=0; // SLAVE SELECT
RC6=1;
TRISB4=1; // SERIAL INPUT
TRISB6=0; // SERIAL CLOCK OUTPUT
ANSEL=0; //digital input output
ANSELH=0;
SSPCON=0;
SSPCON=0X31;
SSPSTAT=0;
SSPSTAT=0X80;
PIE1=0; // DISABLE PREPHERAL INTERRUPT
INTCON=0; // DISABLE ALL INTERRUPTS
// intializing writing to write in the status register
RC6=0;
SSPBUF=0X06; // SEND WRITE ENABLE INSTRUCTION TO THE EEPROM
while (!BF) continue; //WAIT FOR TRANSMISSION TO COMPLETE
z=SSPBUF;
RC6=1; // TURN OFF THE CHIP (NECCESSARY TO START WRITING
_delay_ms(50);
// intializing the STATUS register
RC6=0;
SSPBUF=0X01; //write to STATUS register instruction (WRSR)
z=SSPBUF; // READ WHAT'S IN BUFFER TO CLEAR
SSPBUF=0X00;
z=SSPBUF;
RC6=1;
// DELAY FOR THE WRITE CYCLE 5ms
_delay_ms(50);
//-------------READ STATUS REGISTER TO CHECK---------------
RC6=0;
z=SSPBUF;
SSPBUF=0X05; //RDSR Read STATUS register
// STORE THE STATUS REGISTER IN THE INTERNAL EEPROM
EEADR=0X00;
EECON1=0X04;
EEDAT=z;
GIE=0;
EECON2=0X55;
EECON2=0XAA;
WR=1;
GIE=1;
while(WR) continue;
RC6=0;
z=SSPBUF;
// checkstatus(); //check the statuse of the EEPROM
_delay_ms(20);
// intializing the STATUS register (READ)
polling:
RC6=0;
SSPBUF=0X05;
z=SSPBUF;
SSPBUF=0X05;
z=SSPBUF;
if((z&0x02)!=0X02)
goto polling;
RC6=1;
RC6=0;
SSPBUF=0X05; //read STATUS register instruction (WRSR)
SSPBUF=0X05;
z=SSPBUF;
RC6=1;
//______BEGIN WRITING_______
RC6=0;
SSPBUF=0X02; // INSTRUCTION TO WRITE
SSPBUF=0X00; // SEND HIGH ADDRESS
SSPBUF=0x13; // SEND LOW ADDRESS
//SEND DATA
SSPBUF=0x48; // data to write
RC6=1;
_delay_ms(20);
// intializing RECIEVING
RC6=0; // TURN CHIP SELECT ON
SSPBUF=0X03; // READ INSTRUCTION TO THE EEPROM
SSPBUF=0X00; // ADDRESS high to read
z=SSPBUF;
SSPBUF=add; // ADDRESS low TO READ
z=SSPBUF;
EEADR=0X01;
EECON1=0X04;
Read:
x=SSPBUF;
add++;
EEDAT=x;
GIE=0;
EECON2=0X55;
EECON2=0XAA;
WR=1;
GIE=1;
while(WR) continue;
EEADR++;
if (add!=endadd)
goto Read;
RC6=1;
TRISC=0x00;
while(1)
PORTC=0X01;
continue;
