PIC16F690 Hi tech C Interrupt problems
sundhir52
Hi, i am trying to get a external interrupt working in the PIC16F690, the code seems to be ok, but when i try simulating the program in the mplab sim it just jumps straight to the ISR holds there for a while and then jumps to the infinite loop.
i am using Hi tech C compiler, and trying to just toggle the PORTB on the external interrupt, but a am at a loss as to why its not working . . . .
any help will be greatly appreciated
#include <htc.h>
#include "delay.h"
void main(void) @0x00
	//Initialisation
	TRISA=0xFF;
	TRISB=0x00;
	TRISC=0x00;
	PORTA=0xFF;
	PORTB=0x00;
	PORTC=0x00;
	ANSEL=0x00;
	ANSELH=0x00;
	WPUB=0x00;
	GIE=1;
	INTEDG=1;
	PEIE=1;
	INTE=1;
	while(1)
		PORTC=0x05;
		DelayMs(20);
		PORTC=0x06;
		DelayMs(20);
		PORTC=0x0A;
		DelayMs(20);
		PORTC=0x09;
		DelayMs(20);
	return;
//Interrupt Handler
static void interrupt int_handler(void) @ 0x10
	if ((INTF&&INTE))
		PORTB=0XFF^PORTB;
		INTF=0;
	return;
I thought that the high/standard interrupt vector was at 08h .
# pragma code Inter=0x08
# pragma interrupt chk_isr
void Inter ( void)
_asm
 GOTO chk_isr
_endasm
void chk_isr ( void)
//check the flags
You have a couple of things wrong with your code.
On the 16 series chip the interrupt vector is at location 4.
The return in the interrupt - remove it as you will miss the context restoring code.
Stop telling the compiler where to place code. It already knows and you will force it to do silly things.
#include <htc.h>
#include "delay.h"
void main(void)  [COLOR="red"]// @0x00   remove[/COLOR]{
	//Initialisation
	TRISA=0xFF;
	TRISB=0x00;
	TRISC=0x00;
	PORTA=0xFF;
	PORTB=0x00;
	PORTC=0x00;
	ANSEL=0x00;
	ANSELH=0x00;
	WPUB=0x00;
	GIE=1;
	INTEDG=1;
	PEIE=1;
	INTE=1;
	while(1)
		PORTC=0x05;
		DelayMs(20);
		PORTC=0x06;
		DelayMs(20);
		PORTC=0x0A;
		DelayMs(20);
		PORTC=0x09;
		DelayMs(20);
	return;
//Interrupt Handler
static void interrupt int_handler(void) [COLOR="red"]// @ 0x10 remove[/COLOR]
	if ((INTF&&INTE))
		PORTB=0XFF^PORTB;
		INTF=0;
	[COLOR="red"]//return;  remove[/COLOR]
void Inter ( void)
_asm
 GOTO chk_isr
_endasm
//check the flags
hey i tried you way but now it just gives me compile errors on the _asm instruction . . . ??
hey mike, thanks i have removed the addresses,
it still does not resolve my problem of the program just entering at the interrupt handler though
hey thanks it all works now, turns out there was a problem with my hi-tech C. I installed a 9.71a and now it works perfectly, thanks for all the help
