PIC16F628 Rounding result of division?
Zasurus
I am fairly new to this and feel like I am getting somewhere will most things but the Maths functions! I have found loads of functions on piclist.com like * and / but can't work out a quick(ish) way to round the 24bit result of my division?
For example I have a result of a division = 25.658
so the function I have got from piclist is great and gives me two numbers the first is the result = 25 and the other is the remainder = 658 (everything after the decimal place). But I can't find anywhere with a function to tell me if a 24bit remainder is > 55555555 etc...
HELP! PLEASE! :D
Thanks!
Before the division add the equivalent of 0.0005 * the number you are dividing by. If this doesn't work then you need to post more information.
Thanks for the quick reply. :D
I don't think I understand what you mean? How can I * by 0.0005 as that is not a integer? :confused:
Here is an example of my code to divide two values that I want to round up/down depending on the remainder:
Thanks again! :eek:
;Divide:
; 15900/1600 = 9.9375
; so round up to 10
   ;15900
    MOVLW   d'28'
    MOVWF   nratorL
    MOVLW   d'62'
    MOVWF   nratorM
    CLRF    nratorH
   ;1600
    MOVLW   d'6'
    MOVWF   denomL
    MOVLW   d'64'
    MOVWF   denomM
    CLRF    denomH
    CALL    Divide_24x24
   ;Result:           nratorH  nratorM  nratorL
   ;Remainder:        remainH  remainM  remainL
;Divide:
; 15000/1600 = 9.375
; so round down to 9
   ;15900
    MOVLW   d'152'
    MOVWF   nratorL
    MOVLW   d'58'
    MOVWF   nratorM
    CLRF    nratorH
   ;1600
    MOVLW   d'6'
    MOVWF   denomL
    MOVLW   d'64'
    MOVWF   denomM
    CLRF    denomH
    CALL    Divide_24x24
; SUBROUTINE - 24 BIT DIVISION  from  TONY NIXON
; numerator:        nratorH  nratorM  nratorL
; denominator:      denomH   denomM   denomL
; result:           nratorH  nratorM  nratorL
; remainder:        remainH  remainM  remainL
Divide_24x24:
      movlw     d'24'      ; set decimal 24 loop count
      movwf     BCount
      movf      nratorH,w ; copy Numerator into Shift Holding ram registers (w-reg)
      movwf     shiftH
      movf      nratorM,w
      movwf     shiftM
      movf      nratorL,w
      movwf     shiftL
      clrf      nratorH   ;  clear final Answer Numerator Ram locations
      clrf      nratorM
      clrf      nratorL
      clrf      remainH  ;  clear final Answer Remainder Ram locations
      clrf      remainM
      clrf      remainL
dloop:
      bcf       STATUS, C  ; bit clear Carry Flag in STATUS register
      rlf       shiftL, f  ; Shift numerator(dividend) Left to move
      rlf       shiftM, f  ; next bit to remainder
      rlf       shiftH, f  ; and shift in next bit of result
      rlf       remainL, f ; shift carry (next Dividend bit) into remainder
      rlf       remainM, f
      rlf       remainH, f
      movf      denomH,w
      subwf     remainH,w  ; subtract divsor(denomH) from(newly shifted left) Remainder HIGH byte.
      btfss     STATUS, Z
       goto     nochk        ; skip if result was ZERO from good subtraction result
      movf      denomM,w
      subwf     remainM,w  ; subtract divsor(denomM) from(newly shifted left) Remainder MIDDLE byte.
      btfss     STATUS, Z
      movf      denomL,w
      subwf     remainL,w  ; subtract divsor(denomL) from(newly shifted left) Remainder LOW byte.
nochk:
      btfss     STATUS, C   ;  Carry SET? then denom is larger than reemainder
      goto      nogo
      movf      denomL,w
      subwf     remainL, f       ; Subtract denominator from remainder value in Low Byte
      btfsc     STATUS, C       ; Carry Set? Then execute fixup code for when a borrow is generated
       goto     nodec_remainM   ; when no borrow bit is needed from the higher byte positions.
      decf      remainM, f      ; Decrement to Borrow from Middle Byte, because carry was SET.
      movf      remainM,w
      xorlw     0xff             ; Check if rollover from Borrow occurred. remainM value went from 0 to 0xFF
      btfsc     STATUS, Z
       decf     remainH, f       ; ZERO bit set, yes rollover, so Decrement to Borrow from High Byte, too!
nodec_remainM:
      movf      denomM,w
      subwf     remainM, f       ; Subtract denominator from remainder value in Middle Byte
      btfss     STATUS, C
       decf     remainH ,f      ; Decrement High Byte, to borrow 1 bit
      movf      denomH,w
      subwf     remainH, f      ; Subtract denominator from remainder value in High Byte
      bsf       STATUS, C       ; set CARRY bit to rotate in Numerator Result next.
nogo:
      rlf       nratorL, f  ; rotate Numerator result left 1 bit
      rlf       nratorM, f
      rlf       nratorH, f
      decfsz    BCount, f   ; decrement the Loop Bit Counter
       goto     dloop
      return                 ; all done
Sorry, I assumed you wanted to round the last digit.
For what you are doing, 15900/1600 = 9.9375, you can add half the divisor and just do the integer part. (15900+800)/1600 = 10.4375. Alternatively, after the integer divide you can check bit 7 of remainH - if it's set then increment the integer answer.
@Mike, I suspect this is what you were going to suggest.
