PIC SPI, how to tell when SSBUF is finished transmitting?
Fred.Amoson
I'm working with a PIC with hardware SPI. In order to send the data through the SPI you just write to register SSPBUF. However, I've been looking through the data sheet and I can't find what tells you that the transfer is complete. Do you have to add a delay yourself (as I am doing now) or is there some variable I can check to see when it is done? I've read all through the datasheet, and tried different things, but nothing has worked except for the delay yet.
16F88 in asm
spisend	movwf	SSPBUF
	BANKSEL	SSPSTAT
spiloop	btfss	SSPSTAT,BF
	goto	spiloop
	BANKSEL	SSPBUF
	movf	SSPBUF,W
	return
16F819 in asm
	BANKSEL	SSPSTAT
	goto	spiloop
	BANKSEL	SSPBUF
	movf	SSPBUF,W
	return
dsPIC 30F4013 in C
int spiout(int send)
	CS = 0;							//CS low
	SPI1BUF = send;
	while(!SPI1STATbits.SPIRBF){}
	CS = 1;
	return SPI1BUF;
And if your program is pressed for time you can use an interrupt.
