PIC instruction: SUBLW
eblc1388
Active Member
On PIC programming.
Can anyone gives an explanation of what is actually meant by "to reverse a sequence of numbers" from the following:
Using the PIC Subtract Instructions
In general, any time it is necessary to reverse
a sequence of numbers from A to B (where A and B
are both in the range of 0 to 255), you can use
SUBLW	A+B
which will work even if the sum A+B is greater than 255.
If you have two numbers that you want to switch between, such as 15 and 47 then a simple way to do it is to calculate 62 (47+15) - N.
EG
62 - 47 = 15
62 - 15 = 47
It's a quirk of how the SUBLW works that makes this possible. The instruction subtracts W from a literal and so in the above example, W will flip between 47 and 15 every time the instruction SUBLW 62 is executed.
I don't think I explained that very well.
Thanks, Pommie.
Just wonder as mentioned in the above code, whether the compiler would complaint if the value of the literal is larger than 255, says 199 & 201:
SUBLW 400 ;A+B larger than 255
You would just use the 8 bit value, the Pic will treat it as 9 bit any way - the 9th bit being the carry.
To switch between 200 and 100 do
SUBLW 44
Because
44-200 = - 156 = 100
and
44-100 = -56 = 200
HTH
It will do,
W=(Speed_Warning - Speed_Warn_Hysteresis) - Valid_Speed
