riccardo
I'm trying to use the 8-bit result from an ADC to make a time delay. It is working except that time delay is only increasing after the input goes above 2.5V. The input is 0V to 5V from a 1k POT.
Any ideas why it would not start working until half way?
It is a 12F675, Main code below...
; ADC CONFIGURATION
BCF STATUS,RP0 ; BANK 0
BCF ADCON0, ADFM ; Left justified (clear and use just ADRESH for an 8bit result)
BCF ADCON0, VCFG ; Vdd reference
BCF ADCON0, CHS1 ; Set AN0 as analogue input
BCF ADCON0, CHS0 ; Set AN0 as analogue input
BSF STATUS,RP0 ; BANK 1
MOVLW b'00010001' ; Fosc/8 (2us), AN0 is selected for reading
MOVWF ANSEL
; The output pulse with delay
DISCHARGE
BSF DISCHARG ; DISCHARGE
CALL READPOT
CALL WAITPOT
BCF DISCHARG ; END DISCHARGE
RETURN
; Get analogue input
READPOT
BSF ADCON0, ADON ; Enable AD
BSF ADCON0, GO ; Start AD conversion
AD BTFSC ADCON0, GO ; TEST if conversion is finished
GOTO AD ; Loop until conversion is done
MOVF ADRESH, W ; High side byte from AD (8-bit)
MOVWF POT ; Stores ns delay value in POT
BCF ADCON0, ADON ; Disable AD
RETURN
; Time dealy
WAITPOT
INCF POT ; make sure not zero
WAITPOTL
DECFSZ POT,F ; Decrement POT
GOTO WAITPOTL ; Loop until 0
RETURN
