PIC ADC analogue voltage reading
richacm
Hi just realised I should have posted this in the Micro controller forums.
Anyway here it is...
I am just writing some PIC code that will read a 0V-5V analogue value from its AN0 pin. The question I have is what value does the reading relate to in the code? E.g. 0V = 0 but is 5V = 255 and 1V = 51 (255/5)? Or is there some other values for each of these?
Thanks in advance,
Craig
For an 8-bit A/D value, 5V would be 255 and 0V would be 0.
For a 10-bit A/D value, 5V would be 1023 and 0V would be 0.
Here's an easy calculation for it:
For 8-bit: ADRESH Value = (MeasuredVoltage/VREF)*256
For 8-bit: ADRESH/ADRESL Value = (MeasuredVoltage/VREF)*1024
VREF is your voltage reference, which is typically the PIC's internal 5V taken from VDD if you're not supplying your own.
Oops! Second line should be 10-bit.
If you're using a 10-bit A/D such as what many PICs have, but you want an 8-bit result, just set it to left justify, read ADRESH and ignore ADRESL.
If you want a 10-bit result, set it to right justify and read both ADRESH and ADRESL.
