Pic 16f88
no1010
Pic 16f88 Paralell operations
I'm studying Mechatronics and they gave us a rather complicated microcontroller task in our first semester. We have to program it in Assembly!
I'm having some problems with my program, I know how to do each part seperately, but I do not know how to combine them and make them run simultaneously.
What I am trying to do is to have a stepper motor run, it's speed can be chaged with a pot, and a photointerrupter counting the amount of turns/second and then displaying the output in binary up to 10.
I'm still busy with getting the steper motor to run, I'm having some trouble with noise, but I have no idea how to do the counting, then the math and displaying it while the motor is still running. As far as I understand it, microcontrollers run linear and cannot do parralell operations. How would I solve this problem?
Thanks in advance!
Firslty you need to look at the tutorials at Nigel's pages
As far as parallel functions (I assume you mean multitasking) most processors run fast enough to appear multitasking!! counting, driving steppers and running a display will be easy for the smallest of devices.
As YOU control a stepper motor you will know the count before hand.
Ian
Use a timer interrupt to run the stepper motor and vary the time to speed up/slow down.
I don't understand why you need a photo interrupter as the speed is simply how fast you step it. However, connect it to RB0 and use an interrupt to count.
Read the ADC and write the display in your main code and all should work well.
I posted some stepper code in C in this thread which might be usefull.
Hi thanks for the replies,
the reason I'm using a photo interrupter and not reading the speed directly is because my lector wants me to do some calculations before showing an output.
