pic 16f876 delay routine
kenobe
Hi
I am working on a 16f876 data acquisition project.
I need a short assembly delay routine which can produce delay of 1 ms to 100 ms. I have search the net and do not get one.
Can someone pls tell me how to do it ? .
I am not using timer interrupt.
delay
HI gremcc
Thanks for your help, I have visited the site and got the codes.
But my problem is how do I transform these codes into a assembly routine so that I can call it from a C program.
I will appreciate very mush if you can help me in this.
If your using C, then there should be a 'pre-made' routine to perform a delay. Coming from a PIC Basic perspective its something like
DelaymS(100)                ' Delay for 100 mS
However, if you want to place assembler code in your program, then check your compilers help file, search for "asm", and it should look something like this
While 1 = 1
     Gosub Assembler_Code
Wend
Assembler_Code:
[INDENT][ASM]
'ASM Code goes here
[ENDASM]
Return[/INDENT]
