PIC 12F508 Call & Goto
Suraj143
Active Member
How can I achieve the "Call" instruction above 256 boundary in program memory?
The "Goto" instruction works in all 512 locations.
But "Call" instruction only works in upper 256.
Place it in the lower 256 bytes of program ROM like so -
		org		0x000		;reset vector
		goto		START
		<place subroutines here>
START		<place main code here>
Hi Jon thanks for your input.But see according to your method if I want to use "Call" instruction above 256th location it will not work.
		org	0x100		; 256 program memory
Main_Loop	nop
Do_Pattern_1	movlw	b'00010101'
		movwf	GPIO
		call	Delay
		movlw	b'00001010'
		movwf	GPIO
		call	Delay
		movlw	b'00000100'
		movwf	GPIO
		call	Delay
		movlw	b'00001000'
		movwf	GPIO
		call	Delay
It doesn't matter where the call instruction itself resides. It matters where the subroutine that you are calling resides.
On the 12F508, the address that the program counter gets modified with on a call or a goto instruction come from the lower 9 bits of the instruction itself (bits 0-8). However, on a call instruction, bit 8 is always clear. This means that you can only place subroutines in the lower 256 bytes of program ROM.
However, with the page access bit in the STATUS register (bit PA0), you can also place them in the lower 256 addresses of the upper half of memory.
So if you plan to place them in the lower half of program ROM, you have to type out your code as I illustrated above. If you plan to place your subroutines in the lower half of the upper half of program ROM, then you can do this instead -
		goto		START
		org		0x200
However, if you place your subroutines between addresses 0x200 - 0x2FF, you have to use a bsf instruction to set bit PA0 in the STATUS register prior to calling the subroutine.
		bsf		STATUS,PA0
		call		SubroutineName
Hope this helps.
