photoelectric sensor to PC COM port
draze75
Hi Guys,
Does anyone knows how to connect the photoelectric sensor, Optex VR-1000T to computer via RS-232 port ? I need to read the sensor signal from the computer.
My project is about to detect the vehicle movement from 1 stage to another stage.
Thanks!.
Hi Guys,
Thanks!.
The datasheet for that model says its a relay contact output, can you confirm that.?
Use a Control pin input on the PC's 9Way RS232 connector, using Visual Basic you could write a short program to detect the pins state.
https://www.aggsoft.com/rs232-pinout-cable/pinout-and-signal.htm
EDIT:
Private Static Sub MSComm1_OnComm()
    Dim ERMsg$
   Select Case MSComm1.CommEvent
        ' Event messages.
        Case comEvReceive
        Case comEvSend
        Case comEvCTS' >>>>>>>>>>>>>>>>>>>>>> use one of these control signal events
            ERMsg$ = "Change in CTS Detected"
        Case comEvDSR
            ERMsg$ = "Change in DSR Detected"
        Case comEvCD
            ERMsg$ = "Change in CD Detected"
        Case Else
            ERMsg$ = "Unknown error or event"
    End Select
End Sub
