Photo sensor 12vol wiring ?
Andrew Sabados
Please I need help with my project ! I have a 12 volt strobe light with a toggle switch for on/off. I need to wire a photo eye that will turn off (over-ride) the switch under dark conditions . I have the light, switch and photo eye, but can't seem to get it to work.
Do I need another component in the mix?
Thanks,
Grateful Amateur
one hint, maybe a transistor, resistor, diode and relay. other ways may work also...not very descriptive.
Thanks,
Grateful Amateur
There is likely several ways to go about this. Things would go much easier if you could please post a schematic of what you have. Could use a comparator in a light / dark sensor with a relay to bypass the switch but without knowing exactly what you have it is hard to say the best method.
Ron
