Phillips Dvd Remote Codes
jagadeesh1987
Dear All
I am decoding Philllips Dvd remote ,After decoding all the keys and analyzing the waveforms it is following Bi -Phase (Space ) encoding technique .
My problem is i am getting two different codes for single key as shown below
button 2 --- 110011000011000000011------------->(21 bits)
button 2 --- 1100110000011000000011----------->(22 bits)
Power --- 110011000011010100100------------->(21 bits)
power --- 1100110000011010100100------------>(22 bits)
Please suggest solution for me for preparing lookup table for further proceedings
Dear Nigel Goodwin
Thanx for your quick response ,i compared with RC 5 protocol,but its not matching with it . And my problem is i am unable find any particular protocol for above codes which i mentioned
Looks like standard RC6 mode 0 protocol to me, as described here:
https://www.sbprojects.com/knowledge/ir/rc6.php
Note that the trailer/toggle bit is twice the size of the other bits, this may cause confusion
I will look harder when I get back from work
EDIT: I see that the "control" byte is 0x04 and the information byte is 0x02 (hexadecimal) while the toggle bit is 1
On alternate button presses the toggle bit will toggle 0 and 1 alternately, and don't forget that the toggle bit is double-sized, which makes decoding a little trickier.
Thanks for your response , if possible can you write the above waveforms in the form 0`s &1`s , so that i will compare all my decoded data .
And my another problem is i am getting 21 & 22 bits for single key .
Here's some RC6 decoding data in MicroPascal - it describes the protocol reasonably well.
unit Rc6_Decoder;
// D. Rosseel
// Original: 26-03-2009
// Latest update: 21-04-2009
// For 36Khz IR receivers with inverse output (= output active low), like the TSOP1736.
// The output of the Rc6 receiver is to be connected to the PIC's external interrupt pin (PortB.0).
{.$DEFINE DEBUG}
// --------------- interface ------------------
procedure Rc6_Interrupt;
// always to be called (unconditionally) in the program's "interrupt" procedure
procedure Rc6_Init;
// to be called before the Rc6 decoder can be used
function GetRc6(var Toggle, System, Command: byte): boolean;
// Returns true if an Rc6 code is received and decoded.
// If true, then "Toggle", "System" and "Command" contain the last decoded Rc6 code.
// Restarts Rc6 decoding (was stopped until this function gets the Rc6 data already received).
{$IFNDEF DEBUG}
implementation
{$ENDIF}
const Rc6_IDLE            = 0; // Rc6 decoder state constants
      Rc6_DECODING_HEADER = 1; // leader, startbit, mode bits and Toggle bit decoding
      Rc6_DECODING        = 2; // System and Command decoding
      Rc6_COMPLETED       = 3; // correct Rc5 code received and decoded
var Rc6_State: byte;           // State of the Rc6 decoder
        The timer0 requires a clock (after prescaler) of 62.5 KHz. This means, when the
        CPU clock is 4 MHz a prescaler value of 16 is required: 4 MHz / 4 / 16 = 62.5 KHz.
        The time/timerstep is then 16 microsecs. (1/62500)
        For other CPU clock speeds the prescaler has to be adjusted accordingly, or
        if not possible both prescaler and "Rc6_TIME_..." constants have to be adapted.
const
      Rc6_NR_Rc6_Bits = 16;
      // Leader pulses
      Rc6_LEADER_TIME_BOUNDARY = 125;
       { the leader Time "On" = 2666 uS = timer value 167
         the leader Time "Off" = 889 uS = timer value 83 }
      // "normal pulses"
      Rc6_TIME_BOUNDARY  = 42;  // below 42 = short, above = long
      { 1 bit time = 888 uS
        "short" time = 1/2 bittime = 444 uS, = timer value 28
        "long"  time = 1 bittime = 888 uS,  = timer value 55 }
      // First bit after the Toggle (trailer) bit
      Rc6_TRAILER_TIME_BOUNDARY = 69;
      { this is 889 + (444 / 2) millisecs = timer value 69 }
      Rc6 Bit coding:
       <--1 bit Time -->
               |        "0" bit, no IR signal to IR signal transition
               |        "1" bit, IR signal to no IR signal transition
      RC6 coding/timing
      Legend: (1) = leader
              (2) = startbit (always "1")
              (3) = 3 mode bits (here always "000" is expected)
              (4) = trailer bit (= Toggle bit). Timing is different from regular bits
              (5) = 8 system bits
              (6) = 8 Command bits
          |<--- (1) ---->|<-(2)->|<-------- (3) -------->|<-- (4)--->|<--- (5) --->...<--- (6) --->|
 Edge# -> 0        1     2   3       4   5   6   7   8   9    10    11  12
          ---------      ----        ----    ----    ----      ------    ----     Case A:
          |        |     |   |       |   |   |   |   |   |     |     |   |        Toggle = 0 and
       ---         ------    --------    ----    ----    ------      ----         first sys bit = 0
          ---------      ----        ----    ----    ----------      ----         Case B:
          |        |     |   |       |   |   |   |   |         |     |   |        Toggle = 1 and
       ---         ------    --------    ----    ----          ------      ----   first sys bit = 1
          ---------      ----        ----    ----    ----      ----------         Case C:
          |        |     |   |       |   |   |   |   |   |     |         |        Toggle = 0 and
          ---------      ----        ----    ----    ----------          ----     Case D:
          |        |     |   |       |   |   |   |   |         |         |        Toggle = 1 and
       ---         ------    --------    ----    ----          ----------         first sys bit = 0
var
{$IFDEF DEBUG}
    Rc6_Times: array[50] of byte; // array for the Rc6_Times measured
    Rc6_TimesIndex: byte;         // index/count for above
{$ENDIF}
    Rc6_Bits:  word;              // will hold the received bits
    Rc6_BitCount: byte;           // count for above
    Rc6_PrevBit: byte;            // the value of the previous bit
    Rc6_ShortPulses: byte;        // nr of subsequent short pulses measured
    Rc6_EdgeCount: byte;
    Rc6_Toggle : byte;
    Rc6_Time  : byte;
    Rc6_Error : boolean;
{$IFDEF DEBUG}
implementation
{$ENDIF}
begin
  if (INTCON.INTE > 0) and (INTCON.INTF > 0) then
  begin // Total execution time is about 55 uS at 4 Mhz CPU clock
    OPTION_REG := OPTION_REG xor %01000000; // toggle the INTEDG (interrupt edge)
    INTCON.INTF := 0;
    Rc6_Time := TMR0;   // get time
    TMR0 := 0;          // restart timer
    Inc(Rc6_EdgeCount); // a new edge is there
{$IFDEF DEBUG}
    if Rc6_State = Rc6_IDLE then
    begin
      Rc6_TimesIndex  := 0;
    end
    else
    if (Rc6_State = Rc6_DECODING_HEADER) or
       (rc6_State = Rc6_DECODING) then
    begin
      Rc6_Times[Rc6_TimesIndex] := Rc6_Time;
      Inc(Rc6_TimesIndex);
    end;
{$ENDIF}
    case Rc6_State of
      Rc6_IDLE: //
        begin
          Rc6_State      := Rc6_DECODING_HEADER;
          RC6_EdgeCount  := 0;
          INTCON.T0IF := 0; // reset Timer0 overflow flag
          INTCON.T0IE := 1; // enable timer0 interrupt
        end;
      Rc6_DECODING_HEADER: // the "on" part of the leader has gone
                           // Execution time is about 20 uS at 4 Mhz CPU clock
        begin
          Rc6_Error := true;
          case Rc6_EdgeCount of
            1: if Rc6_Time > Rc6_LEADER_TIME_BOUNDARY then Rc6_Error := false;
            2: if Rc6_Time < Rc6_LEADER_TIME_BOUNDARY then Rc6_Error := false;
            3,5,6,7,8: if Rc6_Time < Rc6_TIME_BOUNDARY then Rc6_Error := false;
            4: if Rc6_Time > Rc6_TIME_BOUNDARY then Rc6_Error := false;
            9: begin
                 then Rc6_Toggle := 1                                           // Cases B and D
                 else Rc6_Toggle := 0;                                          // Cases A and C
                 Rc6_Error := false;
               end;
            10: begin
                  if Rc6_Toggle = 1 then
                  begin
                    if Rc6_Time > Rc6_TRAILER_TIME_BOUNDARY then
                    begin                                                       // Case D ends here
                      Rc6_State       := Rc6_DECODING; // actual data reached
                      Rc6_Bits        := 0;
                      Rc6_PrevBit     := 0;            // the first System bit is a "0"
                      Rc6_BitCount    := 1;
                      Rc6_ShortPulses := 0;
                    end;
                  end
                  else
                  begin
        // Case B (no action here)
                  end;                                                          // wait for the next edge
                  Rc6_Error := false;
                end;
            11: begin
                  begin                                                         // Case B ends here
                    Rc6_Bits        := 1;
                    Rc6_PrevBit     := 1;            // the first System bit is a "1"
                    Rc6_BitCount    := 1;
                  end
                  else
                  begin  // Rc6_Toggle = 0
                    begin                                                       // Case C ends here
                      Rc6_Bits        := 1;
                      Rc6_PrevBit     := 1;            // the first bit is a "1"
                      Rc6_BitCount    := 1;
                    end;
                  end;
                  Rc6_Error := false;
                end;
            12: begin                                                           // Case A ends here
                  Rc6_Bits        := 0;
                  Rc6_PrevBit     := 0;
                  Rc6_BitCount    := 1;
                  Rc6_Error := false;
                end;
          end; // case
          if Rc6_Error then
          begin
            Rc6_State         := Rc6_IDLE; // restart
            OPTION_REG.INTEDG := 0;        // next Rc6 interrupt is negative going
            INTCON.T0IE       := 0;        // disable timer0 interrupt
          end;
        end;
      Rc6_DECODING: // Execution time is about 35 uS at 4 Mhz CPU clock
        begin
          if (Rc6_Time < Rc6_TIME_BOUNDARY) then         // short pulse detected
          begin
            inc(Rc6_ShortPulses);
            if (Rc6_ShortPulses = 2) then
            begin
              Rc6_Bits := Rc6_Bits shl 1;          // store the bit received
              Rc6_Bits.0 := Rc6_PrevBit;
              inc(Rc6_BitCount);
            end;
          end else                                 // long pulse detected
          begin
            Rc6_PrevBit := Rc6_PrevBit xor 1;      // toggle the bit
            inc(Rc6_BitCount);
          end;
          if Rc6_BitCount = Rc6_NR_Rc6_Bits then   // all bits are received
          begin
            Rc6_State := Rc6_COMPLETED;
          end;
        end;
      Rc6_COMPLETED: //
        begin
        end;
    end;
  end;
  if (INTCON.T0IF = 1) and (INTCON.T0IF > 0) then  // timer 0 overflow, timeout
  begin
       (Rc6_State = Rc6_DECODING) then // something is wrong
    begin
      Rc6_State := Rc6_IDLE;  // start all over
    end;
  end;
  INTCON.T0IF := 0; // always reset timer0 overflow flag
end;
procedure Rc6_Init;
{$IFDEF DEBUG}
var I: byte;
{$ENDIF}
begin
  // Timer 0
  OPTION_REG.T0CS := 0;  // bit 5 TMR0 Clock Source Select bit:0=Internal Clock (CLKO) / 1=Transition on T0CKI pin
  OPTION_REG.T0SE := 0;  // bit 4 TMR0 Source Edge Select bit: 0=low/high / 1=high/low
  OPTION_REG.PSA  := 0;  // bit 3 Prescaler Assignment bit: 0=Prescaler is assigned to the Timer0
  OPTION_REG.PS2  := 0;  // Rc6_Bits 2-0  PS2:PS0: Prescaler Rate Select Rc6_Bits
  OPTION_REG.PS1  := 1;
  OPTION_REG.PS0  := 1;
  TMR0            := 0;  // preset for timer register
  INTCON.PEIE     := 1;
  INTCON.T0IF     := 0;
  INTCON.T0IE     := 0;  // disable timer 0 interrupt for now
  // external interrupt
  TRISB.0           := 1; // "Int" input
  OPTION_REG.INTEDG := 0; // start with downgoing edge
  INTCON.INTF       := 0;
  INTCON.INTE       := 1;
{$IFDEF DEBUG}
  for I := 0 to SizeOf(Rc6_Times) - 1 do Rc6_Times[I] := 0;
{$ENDIF}
end;
begin
  Result := false;
  if Rc6_State = Rc6_COMPLETED then
  begin
    Result    := true;
    Toggle    := Rc6_Toggle;
    System    := Hi(Rc6_Bits);
    Command   := Lo(Rc6_Bits);
  end;
end;
end.
@Nigel Goodwin - many thanks, this saves me a lot of time annotating the waveform
@jagadeesh1987 note that Nigel's timing diagram shows mark as high, space as low. Your IR receiver and the waveform you attached show INVERTED signal, where a mark is low, so is upside-down compared to Nigel's waveform diagram.
EDIT: and binary bit decode is:
Leader (2.667mS mark, 0.889mS space) - start bit 1 - mode 000 - double length toggle 1 - 00000100 - 00000010
or shorthand binary:
Leader - 1000 - 1 - 00000100 00000010
Mark = 36KHz IR being transmitted, space = nothing transmitted
Thanks @hexreader , i am getting 2 codes for single key ,so how can i write look up table for 2 different codes for single key press .
You should get the same address and control information for any particular button, only the toggle bit should change.
Sounds as though you are not decoding correctly.
