PCB Footprints- What is a BSC?
dknguyen
Most Helpful Member
Hi. What is this BSC "unit" that I see in the datasheets for specifying IC package dimensions?
BSC Basic Spacing between Centers (integrated circuit package dimension)
from Google
oh...so if something says 1 BSC it still means it's in mm or inches, etc? Not some weirdo other unit?
Might as well throw this question into this thread too since I've been making too many queston threads lately and this one isn't so important.
I need some high current diodes, but I dont need anything else and from all the discount places like Glitchbuster, I can only get MOSFETs able to carry the current I need >10A. If I connected them backwards to use as diodes instead, what do I do with the gate? I just connect it to the source (for NMOS) or drain (for PMOS)?
It would go to the source in both the NMOS and the PMOS....
The drain source diodes are only good for slow speed switching same as a general purpose diode would be. You can't use them in a 100Khz switching power supply.
Oops, yeah that's what I mean: source for both. It makes it useless for reversed polarity protection if I connect the drain-gate of a PMOS.
