PCB Copper fill - ground plane
FusionITR
In my PCB design I have a ground plane on the bottom layer and no copper fill (just routing) on the top layer. Is there any benefit of having a copper fill on the top layer also as a ground plane?
It's more environmentally friendly as less chemicals are used since less copper is etched away. It also helps prevent warping since copper distribution is more balanced across the board with copper fill (as opposed to areas with lots of copper and areas with very little). If the copper fill on top board is connected to +V or GND, it can also work for more noise immunity by working to form capacitances with the other ground and power planes.
JUst don't leave any areas of copper fill floating...make sure it's connected to a signal (preferably a low impedance one), or +V or ground.
Yes
Could use the second ground to help RF radiation.
The second ground may help reduce the impedance of ground.
Because copper is removed not added to a board, it will reduce waist.
I have used a second ground layer as a shield, it will not have current in it because it was connected in only one place.
